meet07 »
https://forums.nicoclub.com/meet07-u64817.html
Fri Jul 12, 2013 7:15 pm
I don't even want to get into what happened to my old motor.....
I mean I have the series 1 harness and ill be using all the series 1 sensors plus the IAT and MAP so I should be good in that department. I considered changing out the cams but with the NEO engine having solid lifters and the series 1 having hydraulic, I would think the clearance on both would be different. I was thinking in order to make the series 1 cas work with the series 2 neo cams, they would need some sort of machining....And if that's the case then I would just purchase another series 1
I called AEM about the series 2 black top CAS working with the 1st AEM EMS but they didn't have much to say. I have the AEM 30-1621U
