Using a z32 tt clutch on a rb25det
scottsi
I posted this in another forum but i guess no one saw or somethin, but as some may know i used to own a z32 tt, and one thing the NA guys were doing were using z32 tt clutches instead of the NA version because it is larger diametere and using the stock flywheel tt would result in more torque. and for them to do this they grinded the inside of the bell housing ( i think i'll have to find the thread) and put washers on the starter. since a rb25det uses a z32 NA clutch/fly, couldnt we theoretically do the same, resulting a larger clutch/flywheel that will hold more power, and will cost a bit cheaper if not the same. just wondering
Joe
im pretty sure its not a Z32 flywheel. im fact im almost positive.
as for more torque, how much power are you planning on making here? i mean a good pressure plate and 6/4 puck will hold 500 whp no problem. dont know many people on here going above that.
just seems like a wasted effort to me.
Imissmyturbo
Car: Car's, Turbo's, sking
I was thinking the VG flywheels and RB flywheels have a different # of bolts holding them on.
scottsi
oh alright, that makes sense now and if the bolts are diff it wouldnt work. sorry just trying to help benefit the community =]
Sil240
Car: Nissan S13 "The One Cam Wonder"
the RB flywheel has the bolt pattern of a KA but is more like a NA VG
Ramius83
Car: 1995 240sx SE
Z32 flywheels are an 8-bolt pattern that bolt up to the flywheel.
RB25/RB26 flywheels are a 6-bolt pattern that bolt up to the flywheel.
Now, I know some machine shops that can make flywheels, but then again, that is some serious money. Might be cheaper to just find a supplier from Japan and order from there and pay shipping costs.
Sky240PWR
Car: 1991 Nissan 240SX
well, I have a RB25 and I'm planing on making 550-600whp(already bought the set up), what clutch setup would be the cheapest and most streetable for those kind of numbers???
skillzilla
Youd be fine with a 4 or 6 puck unsprung disc and a nice, stiff plate. SPEC makes kits for NA Z32's and specifically for RB20/25/26, so look into their lineup.
I have a spec stage 3, and it still has a light pedal feel. You could also get a heavier metal disc, like their stage 4 disc, and up the ante a bit. Also, they will give u a 4 puck instead of a 6 puck if you specify that when ordering.
http://www.specclutch.com
Carl H
my cheap arse ebay special XTD racing clutch seems to be holding 450bhp fine.......
lucky7
Car: 97 RB25 S14
i have an RPS 6 puck sprung hub. i havnt used it yet, nor have i talked to anyone that has. supposedly holds up to 520lb ft and has relatively light pedal feel having a sprung hub. well see.
scottsi
i used a cheap arse xtd clutch on my tt z32, it loved the 2nd gear burnouts and redline clutch drops =]
