mckmnstr »
https://forums.nicoclub.com/mckmnstr-u142513.html
Sat Oct 31, 2009 6:51 am
here is my question on parallel wiring if i attach a hot lead to a metal plate and a ground to the led wire will that work.... basically i would solder the positive and negative side of all but one led to the metal plate with power in it, and on the last led in the sequence i leave the ground lead out and ground it... will this work or will only the last led light up? or will i create multiple shorts on each led soldered to the plate....... i was going to test this idea out first on just a row of 5 for my glove box. the reason i want to do this is so they are all aligned in a row and to save on wiring times supply and such. so any one know? or do i have to do it the normal way with lots of wires?
