InsanityInc wrote:You're making the mistake of thinking that a high speed rating makes the whole tire higher performance. That's not really true.
Uhm, considering a speed rating can reflect, to some degree, the internal construction and performance capability of a tire when isn't this true?
Take for example a V rated versus T rated tires. THe T rated tire is not built internally or tread-compound wise, well enough to perform uder high speed loaded conditions. Things such as belt caps, bead filler, bead construction and strenght, and tread compound and desgn (ability to absorb the higher heat generated) all affect this.
Most of these factors are directly related to cornering (IE high performance) of a given tire. Ability to maintain its shape (contact patch) during hard cornering is a function of the items above (mainly having the cap plies, and good bead construction and filler materials..sidewall inserts, etc), large ammounts of heat are generated during hard cornering (again see above), all of which relate directly tyo how a tire recieves a speed rating.
Given it's not the best method for choosing a tire, but >95% of the time, a higher speed rating will denote a tire will perform better at the "performance" criteria than a lower speed rated tire in its class (IE, touring, all season, MP, UHOP, summer UHP, etc).
Obviously, a V rated snow tire won't perform as well in the dry as a V rated UHP summer tire, but that's because of the tires intended purpose.....but I digress...
Something to chew on.
-Chet
