Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Thu Mar 04, 2010 7:57 am
I put up a how to on doing the bellhousing swap (it's listed in the SR FAQ). Gear ratios between the transmissions are identical save for 5th, so you won't notice any difference in gearing unless you're cruising in 5th, and even then it's only a few hundred RPM.
If you're trying to get better 1/4 mile times, I would suggest doing research on gear ratios and what would suit you best. You'll probably have better luck doing a rear end gear change or changing the diameter of your tires.
