Using a Holset HX35 turbo...
SSS
After speaking to an friend about large turbos in the last week, he suggested a Holset HX35 unit from the 5.9L Cummins Diesel engines. He will able to supply me with one rebuilt for a very good price (much less than $1k AUD), so plans for the VF22 have been put right back.
i'd like to hear from anyone with experience with this particular turbo, or know of someone using one.
And for those that say it won't spool til 6500rpm on the SOHC KA, this guy is running one on a 2.3L 4 cylinder mustang and is making 28psi by 4000rpm. Apparently it's the go for upgrading 2.3L turbo Volvo's in Europe too. http://msvorinich.itgo.com/Jan0703.html
Holset's website list max. flow at a pressure ratio of 3.0:1 (30psi) at 0.46 kg/s, or approx. 60 lb/min. Enough for 600hp at the fly on the KA with a 1mm overbore. :D
driftjunke
I just replaced my T3/T4 with the Holset HX35W from the Cummins, I am still breaking my motor in, but that things spools just like the t3/t4, but seems to flow much more air. Once I dyno it, I will let you know more.
J.D.
Red Lightning
I thought those turbos are way too big for a 2.4L, keep us posted on how it spools on a KA.
driftjunke
We had to make a external WG to fit it, but the damn thing skyrockets to 10 psi very quick, right around 3k, I am only running 370's, stock MAF, and no timing management. I at least need the BTM to keep from blowing the motor, I just keep backing off around 5 psi, but I'll keep ya'll posted.
J.D.
chandler
Car: 91 civic hb & 96 S14
if it spools on a 2.3ltr ford, it should spool a little quicker on a 2.4 right?
SSS
Keep us updated driftjunke! Sounds awesome....can't wait to get my hands on this turbo :D
Can you do me a favor and measure the diameter of the compressor housing? I have a feeling it'll be a real tight fit in my fwd engine bay.
donalson
Car: cars, music, computers
i know a few volvo guys using it on the b240ft's... they spool fairly quickly... and are cheap as hell to pick up...
would make a good match for a high boost setup on the 2.4... especaly w/ an extra 8 valves over the volvo's engine
mark
DriFt3r
Car: Racing and Drifting
you guys got any pictures of this turbo? i would like one too, hehee
toki
we all must remember diesel's produce less exhaust gas per capita than a gasoline motor, so a 5.9L diesel isn't going to be running a turbo anywhere near as big as say a 5.9L gas engine.
donalson
what toki said...
the garrett (SP) that was used on the 1.9L TDI vw engines... is ideal for a 1.0L petrol engine...
but that being said the HX35 holset is supposidly around the size of a 60 trim t04... nice sized turbo...
i'll see if i can't dig up pics :)... one guy runnin a holset on the volvo has one w/ a 4" v band exhaust :)... 4" exhausts are just kewl :)
mark
donalson
http://www.pbase.com/kdh51/holset_hx35w
fun pics :) HX35W vs stock volvo 43 trim t3
mark
driftjunke
Right now I am having not so fun of a time with it, I am running an internal wastegate, and haven't had much time to play with the setup to keep it from boosting past 8 psi, I am running 370's and no timing management, waiting for the BTM. I just replaced the rings and the #4 piston so I am still breaking in the motor, and am running only a 3 inch downpipe, so I don't want to blow my motor. Once I do the exhaust tommorrow, it should spool quicker, right now it's hitting 10 psi between 3500 and 4000. I'll throw up some pics tommorrow, to show the sizing.
J.D.
donalson
i know your brakin it the engine still... but hows it feel?... and when do we get dyno and 1/4 info? :)
i'm very tempted to use one on my volvo at some point...
mark
hannibal
Car: Red Line to Glenmont
Thats a big ole turbo...Does it have ball bearings? I know it comes from a diesel, but it spools up WAY fast. 28psi by 4000rpm on a 2.3L is amazing!
donalson
no BBs as far as i know... the bigger thing is to look specificly at the wheels... the housings are huge... but the wheels aren't THAT much bigger...
KAT S14
I can get one of these in REALLY good condition for free, but I kinda ruled it out for the shear size of it but would it work just as well as a T3/TO4E .63 for around 8 psi.
Chingon
Car: 1991 and 1992 hatchbacks
this is a good turbo. Rotary guys use it very often and also upgrade to hx45.
Redline240
Car: 95 240sx
What truck uses the 5.9l cummins? And what years? Might have to call some scrap yards!
Redline
gabossie
Car: Your mom
Dodge Ram
