It's a little tedious enough to FINE tune a normal upgraded injectors. I think it would be kind of hassle to add in a FMU as well. Bigger injectors will supply you with enough fuel.Dustin240 wrote:Anyone using a FMU (rrpr),larger injectors and e-manage at the same time?Had a thought of adjusting the e-manage for larger injectors, and the fmu can give it more fuel under boost than the norm.(more boost)
