Using a 96 KA Megasquirt pnp ecu on a 95?
M374llic4
Car: 04 Titan, 89 KAT
Hello,
I bought a megasquirt DIYPNP ecu for a 96 KA not thinking much of it, and mine is a 95. Since I didnt think ahead I forgot that they are different, Can I still use it, or what might I have to do to make it work?
(ECU came with the needed sensors and pigtails to swap on the harness for the temperature stuff and dizzywheel and all that I just want to know if it will work before I cut the ends off my harness to try it)
Any help would be much appreciated!
Thanks.
Please text if you know the answer asap!
81Three.,.,53Two.,,.six 3.,43
WDRacing
Damn, two new threads the week I'm not here...DAMNIT!
Did you get an answer on this by chance? I have a 95, how are they different from the 96? Is it the OBDII related stuff? If you're going with a full MS I wouldn't think there'd be a problem at all if you have the correct sensors and pigtails.
WD
M374llic4
Well, didn't get it started yet, but should work just fine. It's a DIYPNP, using an obd2 on an obd1 should work fine, but not really the other way around I don't think. I was able to get it to at least connect via laptop and such in car, but that's all. : /
brooin8
Car: Datsun 510 with Ka24e-T
Dry sump oil system using the stock ka PS pump.
M374llic4 wrote:Well, didn't get it started yet, but should work just fine. It's a DIYPNP, using an obd2 on an obd1 should work fine, but not really the other way around I don't think. I was able to get it to at least connect via laptop and such in car, but that's all. : /
Is this project running now?
I have a microsquirt on my KA right now.
M374llic4
Traded the car and everything with it for a supercharged s13, lol.
