MarkEmark »
https://forums.nicoclub.com/markemark-u744.html
Fri Dec 19, 2003 3:21 pm
I'm running a 2.5" exhaust on my car right now (ka-t, 9 psi)--and if I had the choice again, I'd definitely get a larger exhaust. I'm not so sure about 3", but definitely at least 2.75". But, I don't have $500 to drop in a new exhaust; that's what happens when you go from N/A to F/I.
I'm running a catco high-flow cat. My downpipes are crush-bent and incredibly restrictive (I am currently in the process of re-fabricating them). The first section of my downpipe actually had a smaller (very very marginally) inner diameter than the diameter of the opening for the turbine!!!!
The crappy, restrictive design of the downpipes + the catalytic converter were causing quite a bit of back pressure in mine and were causing the boost to go from 9 psi at 5k to 6.5 psi at 6k--The engine was literally being choked at that high RPM.
Then I disconnected the exhaust except for the FIRST downpipe, and the car felt absolutely beautiful. Full 9 psi up to 6k rpm. It felt substantially faster with 200 pounds more weight and no exhaust (my brother/more gas was in the car) than when I ran it before, same conditions, with just me and less gas.
As I said, I'm getting the downpipe sections re-made into TRUE 2.5" piping with TRUE mandrel bends. Then, I'm having a straight-pipe manufactured to replace the cat (I'll just put the cat back on for emissions). If I'm still dissatisfied with how it runs with the straight pipe/rest of the exhaust (which is a 2.5" mandrel bent tanabe), then I'll just disconnect everything except for my two downpipes, at least until I get pulled over for excessive noise :pface
I'm also going to experiment with running the car with just the downpipes/catalytic converter and then nothing else--hopefully the cat will quiet things up a bit.
In any case, listen to me and wait for something a bit bigger!
