S-tec Motorsports »
https://forums.nicoclub.com/s-tec-motorsports-u94813.html
Mon Sep 28, 2009 8:01 pm
I have used alot of cams including tomei.I have checked all of the ones i have put in with a degree wheel.tomei's pins are dead balls on, according to what their "cam card" or lack there of says. procams you need gears. poncams are drop in.
HKS cams drilled pins are not even close, and seem to be unconsistant also.get gears and a wheel, you will need them to get them right, or what the company selling them considers to be correct.i have seen some 256 drop in hks be over 7degrees out of spec.
Modified by S-tec Motorsports at 5:57 PM 9/29/2009
