Useful Info For Ka24de Idle Problem
ArdmoreS14
Car: 1995 Nissan 240SX
If you are having a idle issue and have replaced you dist. cap, but a week or so later it comes back check this...
The rubber seal between the cap and dist. gets dirty. So it lets in moisture and eventually builds up inside there(mine wasnt on the 4 points but inside the long tube part down the side that sends the juice to the rotor) like the corrosion build up on battery terminals. So even though you have just replaced it ,,it will do it some more.. Just a little help and one more thing to look at when hunting down an idle issue on the 240s...Clean it up and if still doing it look at something else
