used sway bars?
Atomic-S14
Car: 2009 Altima 2.5S
would it be worth it to source out and buy a set of used OEM sway bars for front and back, and then spend more money buying end links for it?or would it be better to buy a swaybar kit with all the parts included?are OEM bars as thick as the aftermarket ones?please give me some inputs on this
lrb_2000
Car: '91 Nissan KA-T hatch
I hear fronts are thick enough, it's the rear you want to beef up.. but i'd get end links for the front, and a rear kit.
Red coupe
Car: 92 Nissan 240sx Coupe
wait dont you already have stock sways? aftermarket ones come in different thicknesses.you might also wanna look at getting a rear hicas bar as they are a little thicker then the others
Atomic-S14
my car is a stock 1996 240sxi believe that only the SE models came with stock oem sway bars i found some used oem bars on ebay but dont know if i should get them or the front and back aftermarket package.
Red coupe
I got a 92 base coupe...you sure man? pretty sure all 240's came with front/rear sways....
Axel Grungy
Car: 2001 G20 5spd
just get some suspension techniques ones, they are made for your car and tuned correctly. some s14s did NOT come with rear sways IIRC
Red coupe
really? what a trip....can we get some conformation on this? I have never heard any one say there 240 didnt have 2 sways...maybe Im wrong?(That doesnt happen does it
Juujai
s14 non se models. i can't confirm on the other trims.
240sxjeff
Car: nissan 240sx zenki version
All S14 models come with a front swaybar. SE models have a rear swaybar while the base models don't. JUst get e thicker rear swaybar from suspensiontechnique, progress, or whiteline
Tulsa_S-13
Car: 1991 SR 240sx
Get both the front and back Suspension Tech. bars. I ordered my anti-sway bars from SummitRacing. They had the best price and I believe their UPS ground shipping is free, I don't remember I got 2nd day shipping. But anyway, I installed the rear bar first and drove the car a couple days with it. With just the rear bar installed I noticed that the front has a tendency to feel as if it's lifting around turns, aswell as not staying as flat as the rear. With both of the bars installed the car feels ALOT flatter and tighter around turns.
BGdude
Car: 1993 "Shiro" RPS13 180SX
How about S13's, do all trims come with both front and rear sway bar or just SE models? Just curious...
rexhunta
Car: '95 Mitsubishi RVR ( 4G63T and AWD thanks !)
MY10 Forester X LE
BGdude wrote:How about S13's, do all trims come with both front and rear sway bar or just SE models? Just curious...
S13s are easy.. R32 gtr rear swaybar bolts in no hassles. i put one in mine. didn't really notice heaps i have really stiff JIC coilovers, but hey, i know it's there.
Pete
grimple1
Car: 95 240sx Zenki
Axel Grungy wrote:just get some suspension techniques ones, they are made for your car and tuned correctly. some s14s did NOT come with rear sways IIRC
yeah my S14 doesn't have a rear sway. And as the above poster mentioned only the rear aftermarket sways are worth it. The only point of buying an aftermarket for the front would be if it were adjustable... and even that's arguable.
rexhunta
MY10 Forester X LE
grimple1 wrote:yeah my S14 doesn't have a rear sway. And as the above poster mentioned only the rear aftermarket sways are worth it. The only point of buying an aftermarket for the front would be if it were adjustable... and even that's arguable.
I had an adjustable Whiteline Swaybar in my lancer, had 3 settings, and you could diffintely feel them all. On the tightest setting it would pick up the wheel around corners on the rear. was excellent.
Red coupe
I have a base...and sways came on both sides...the car didnt seem to have been modifide at all so I think they came this way...
Koopa Troopa
Car: 1993 Silvia S14
S13 Silvia K's swaybars are 25.5mm thick, S13 HICAS rear bars are 21mm thick. A nice upgrade from the 15mm thick rears the stock 240SX comes with.
Wait, you have an S14 nevermind.. This info is still informative so I'll still post.
