nissanfreak12 »
https://forums.nicoclub.com/nissanfreak12-u177688.html
Fri Dec 28, 2012 9:30 am
How much is he selling it for? It could always be used as a back up or you can get it tuned for what you have since its already socketed. Then you can turn around and sell yours if you wish. ECU don't normally go bad. Stadsport on projectZ does tuning to chips and I think the cost is only $50 for only the chip. Very knowledgeable, vouch for his work.
Bigger injectors don't make too much of a difference unless your able to get more air, bigger displacement, more exhaust flow. Then you would need it tuned for what you have installed, but still, the gains are not usually worth the cost.
