autotech43 »
https://forums.nicoclub.com/autotech43-u4010.html
Sun Jul 13, 2003 3:50 pm
I use Consult daily, we use the Consult11 which has alot faster processing power than the Consult1. You can do numerous things with Consult, although you can only reprogram certain models starting in the year 2000 depending on the model. You also need to have ASSIST loaded onto a PC with the updates, retrieve the DATA from the PC to consult, then connect Consult to the vehicle for the update. With Consult11, you can reprogram some ECM's and TCM's. The cards being shown are for 1990 to around the 1998 models, depending on the vehicle. Consult 11 has three cards. A red card for retrieving DATA, trouble codes. diagnose etc. The orange card is used for DATA transfer, reprogramming of the ECM and TCM. A purple card for the NATS system ( matching the ignition key chips to the vehicle, and the intelligent system on the FX). Another thing to keep in mind, if you attach a scan tool, regardless of make, to a Infiniti vehicle that has the high speed CAN (central area network)system without the high speed adapter, the vehicles CAN computers will all go into failsafe mode. A few of the 2003 vehicles now have high speed CAN.
