Chris28 wrote:Well your civic is obviously fwd, so accelerating puts the weight of the car off of the drive wheels, so you are going to spin tires. Also, unless you drive like a maniac, I really can't see anyone spinning through third gear. You should rethink how you drive/race and your tire compound then see how much you spin.
I don't have personal experience, but if you get a turbo big enough to flow 350-400 whp then it's not going to spool until say 4k rpm, meaning the turbo isn't going to matter what happens off the line. Anything under 500 hp i think you will be fine as long as you can handle it, and then think about the tires.
This is all wrong...
The T3/TO4E in .48 AR is good for 400whp and hits 20psi by 3k.
The good thing about turbo's is that you can run low boost while daily driving and turn it up when ever you want to go faster, be it the track or not. So you can tailor your power level to the amount of traction you have.
WD
