I recently swapped a 93 dohc ka24de into my 90 240sx
along with some hassles making the wiring harness match the engine i started to wonder why the stock tach wouldnt work. the answer is simple
power
there is no power wire running to it, the fsm says its a yellow/red wire that powers it. which is true and i will get back to that in a second.
my new engine has a dizzy coilpack unit, not separate like the sohc, the two together needed a 6 pinned connector and a 2 pin, the harness had a 2 pin a 3 pin and one 4 pinned connector, the 2 pin clicks in, u then have to splice the 4 pin and 3 pin together to make a 6 pin. thats fine and great, but on the 3 pin after u splice there is one wire left, a green/ black, that powers ur tach, run that down to ur ecu and splice it in with ur yellow/red and voila u have a working stock tach! if u notice on ur ecu there is two yellow/reds thats fine, splice it into the one that goes the lowest on the harness, or locate the pig tail smaller sub harness and follow that one in!
any questions just ask
