Use brake fluid for clutch fluid?
stutterr
Car: 1990 240sx
Hey Guys,
I blew up my SOHC last night, I am swapping a new one in tomorrow along with a new trans and clutch disk. I have a bottle of Motul 5.1 brake fluid, can I use this for the clutch fluid?
I searched everyone says use DOT 3, but I use DOT 5.1 brake fluid in my car, so can I use the Motul 5.1 as the clutch fluid aswell?
Let me know.
Thanks
I called PDM Racing,, they told me sure why not...
So yes, you can use 5.1 brake fluid for clutch fluid.
Thanks
dc1984
Car: 93 240sx/98 180sx blacktop sr20det :RIP/ 93 jeep grand cherokee
ive always been told and used dot 3.
stutterr
Car: 1990 240sx
hhmm..well has anyone used dot 5.1?
mexicanracer03
Car: 95 S15FRONTEND SR20DET and 97 2JZ GT4294/ 93 SC300 Black/ 95 SC300 Green
Dot 5 Has a Higher Boiling Point. Normally used on Race Cars.
You can use it but make sure you get all the Dot 3 out b/c they are not conpatible. GL
liquid_cool
Car: 1990 Nissan 240SX KA24DE-T swap 8.6:1cr, duelsprings, ti retainers,supertech pistons, K1 H-beems balanced internals ect ect
mexicanracer03 wrote:Dot 5 Has a Higher Boiling Point. Normally used on Race Cars.
dot 5.0 is not compatible with all others...dot 3.0 dot 4.0 and dot 5.1 are thou......you can actually mix them but you will not get the binifits of using the dot 5.1..id drain it all..and then bleed out any of the old crap before using it..good luck.
pmkls2
Car: 1990 240SX Fastback
That's right on the money. DOT 5.0 was silicone based and all others are glycol based. I usually get a big bottle and do a thorough flush when changing brake/clutch fluid. Anyhow, using the DOT 5.1 is fine and it will mix with any residual fluid left in the system so you're good to go.
