JMT-Z wrote:I have been reading on this site for quite some time and all I have found are random posts here and there about how the JDM VH41 is superior in construction to the USDM VH41, yet I cannot find the source of this statement. Would someone please enlighten me with the differences that they KNOW, not what they heard someone else tell someone else. Im pondering doing a swap using one of the VH-series of engines in my Z32.
Well, lets start with the block...
The Block casting is the same on all VH41, USDM, JDM, RWD, AWD, doesn't matter, the block casting is the same. All versions have the same crank, rods, pistons, and oil pan (which is cast AL btw). The AWD oil pan is obviously different. The USDM VH41 does NOT have the block girdle connecting the mains like the JDM does.
The heads...
Well, where do we start? Nothing is the same JDM to USDM. Take the late oval port VH45 heads and update the design to incorporate the duplex timing chain setup of the VH41 and you have JDM VH41 heads. The USDM heads have smaller ports, different cam cap setups, a single chain on the cam gears, and other odds and ends that make them inferior (from a performance standpoint) to the JDM VH41 heads.
Induction...
The JDM VH41 uses a spider style intake manifold just like the VH45, the USDM VH41 does not. The JDM VH41 uses "header" style exhaust manifolds like the VH45, the USDM VH41 uses a cast log-style manifold.
Accessories...
The USDM and JDM VH41 both have their alternators in the valley between the cylinder banks. The PS pump and AC compressor are on opposite sides as the VH45 and mounted higher up. The VH41 accessory layout makes it much more desireable for a swap into a Z32 since the lines are in the correct locations. The accessories are also mounted higher which gives more swaybar clearance. However, the AL pan is not as easily modded for crossmember clearance as the steel pan of the VH45 is, and no, the pans can't be interchanged. Bolt pattern is different.
How do I know all of this? I have now owned 5 VH45s and one USDM VH41, so I speak from first hand knowledge of those motors. The JDM VH41 information I've mentioned is what I've gathered from reading this forum and internet sites.
USDM and JDM
