fyrcomm »
https://forums.nicoclub.com/fyrcomm-u105256.html
Sat Sep 13, 2008 12:46 am
i ran it into the center compartment just below the head unit. pretty easy too, just get the shift knob off, then the plate, and pull out the compartment while disconnecting the power outlet. i used a 1 inch spade drill bit since i needed to fit the ipod adapter through it. ill post some pictures later if i get the chance
when i took out the shifter, i noticed it would probably be pretty easy to bring it into the center console, also... but of course you still need to drill a hole.
when the dealer installs the ipod adapter they usually run it into the glove compartment, which i think would be more difficult, but if nissan can do it, i'm pretty sure someone on this forum knows an easy way to do it
