does the USB Flash Drive Size have a Limit of 16GB if so, is there a way around it ? i've tried larger drives like 32gb and 64gb and it does not recognize them.
thanks in advance!
Thanks but they're not the same vehicle. Your 2015 'S' is a 2nd gen model. The OP has a 2015 Select which is a 1st gen model.dubnationd wrote: ↑Wed Sep 18, 2019 6:00 pmi have no problems using 32GB USB Flash Drives 2015 rogue S.
you're flash drive might be defective/damaged.
