Till you miscalculate and pass a car and face a semi headon......oh you said interstate driving.
Or you take a summer trip when it's 100F driving thru S. Georgia with AC on.
Mostly the problem is lack of maintenance [plugs, deposits, restricted air flow making the already lean cruise really lean for a second in low speed tip in throttle.
Saving $4-$4.40 on a 8 hour interstate trip maybe significant to some...........only trying it will tell you what to do on your car.You can always refill at 4 hours and make most of the problems start to go away.
The air velocity thru the valves is much higher on a 2 valve V8 at 2,000 rpm than on a 4 valve engine..........32valve V8 have a hard time cruising at 60 mph [2,000 rpm] other wise you would see much low diff gearing like in US V8 which can amble/lug along at 1600 rpm [Corvette].............32valve have very little swirl/tumble till 3,000 rpm.
The Q 2-1.5" intake valve have a combined area of 3.534 square inches vs single 1.94" [350 chevy] 2.956 square inches.
Try a set of these $6,000 heads on your IROC:
http://www.ronsraceshop.com/co...B.php
