UhhOhhh »
https://forums.nicoclub.com/uhhohhh-u43076.html
Wed Aug 02, 2017 8:48 am
That's correct. I tried to change over to the SAT prior to install and was unable to. I noticed the tuner box. I installed the box per directions and grounded the box to the screw that is on the tuner cradle.
I tried it the first time and it wouldn't switch to SAT, and no joy. I checked the harness and wiring and it looked good. I ended up changing the ground point to one on the roof of the trunk. It sparked slightly when I did this meaning it was a good ground.
I have read through the troubleshooting guide and did everything they said. I think this is an Infiniti harness issue.
Would running stereo diagnostics help with it and what would I look for?
Thanks for the help
