From what I've understood, if you have an SL model, your V should be prewired. If you have an S model with power package, your V might be prewired as well. In any other situation, you won't have it prewired.ElDiablo wrote:all you have to do is look under the hood on each side of the back area where the radiator is in front of each side of the engine. they should just be hangin around.
Thanks for the help everyone. I've searched the thread myself and the link was an invalid topic. I think it was the same link you threw at me. Well, if anyone happens to stumble upon anything else regarding this pls let me know. Thanks once again...mdamatas wrote:Here's a similar thread:zer...ights
This comment specifies where you should look:
Good luck!
