crzycrkr wrote:O2 sensor is new. Cat is working fine, Egr is working fine. I'm not too close to yorba linda, why? The smog tech still thinks I am running lean. The ecu is not throwing any codes. I think I am going to need to start testing other sensors. Where should I start? How can I check A/F ratio.THanks for the response.
First smog tech's don't know ****. That's why they are smog techs.My smog tech said I was running lean too, I simply had an exhaust leak.
Try and get the emissions test done when your car is "cool."Most of the time the smog tech's will rev the **** out of the car and/or let it idle for a while before giving it a test. This is good at heating the catalytic converter up to burn more hydrocarbons, but you don't have that problem you need cylinder temps to be lower..
1. I'd go to a different shop, you never know if he's ****ing you.(I've heard smog repair shops advancing timing etc. just to make simple $100 "repairing" the car.)
2. Tight bolts that go from manifold to CAT.
3. Take out EGR tubes and clean them.
4. CRC Guaranteed to Pass Emissions Formula
5. Colder plugs?
6. Smaller plug gap...
My numbers looked like yours, I barely failed at 15mph but failed hard at 25mph. I had a exhaust leak before the cat.
