urgent timing question...KADE
drftnassmofo
Car: 84 s12 ca18et-TRADED
85 s12 ca18et-SOLD
92 fastback-SOLD
91 fastback-SOLD
90 coupe KADE swap-SOLD
06 Infiniti M45
i just got my new head on and i got it started but i belive theres 4 diff. rotor positions you can put the dist. in at. 2 of those positions the car idles near perfect and then i tap the gas and it wants to die. the other 2 positions the idle is pretty high but also very unstable. so my question....is it possible that i just missed time by a notch on the gears? anyone ever have this problem?
LayNLow240
Car: 92 240 coupe
yeah, i would say your off a tooth or so. there are 2 dots on the gear. the closest one to the dis needs to line up with the little indention on the dis. then line up the bolt holes so they are straight and push it in and you should be good to go. if you need pictures, search for a write up on timing related articles.
drftnassmofo
85 s12 ca18et-SOLD
92 fastback-SOLD
91 fastback-SOLD
06 Infiniti M45
im not sure i get what your saying. heres pics at TDChttp://i4.photobucket.com/albu...7.jpg
drftnassmofo
85 s12 ca18et-SOLD
92 fastback-SOLD
91 fastback-SOLD
06 Infiniti M45
drftnassmofo
85 s12 ca18et-SOLD
92 fastback-SOLD
91 fastback-SOLD
06 Infiniti M45
hourly bump!! please help me out! anyone in the chicago west suburbs that knows their ka's. . . i thought i did but obviously not i will pay someone for their help!!!
Modified by drftnassmofo at 9:10 PM 7/22/2007
Florida240sx
Cams look to be correct. Could just be your dizzy. Is it in good shape? Look for cracks...
drftnassmofo
85 s12 ca18et-SOLD
92 fastback-SOLD
91 fastback-SOLD
06 Infiniti M45
theres no cracks on it. i thought i might have missed a cam gear by a notch so i took the top cover off and the top chain and re timed the cams. still the same issue
drftnassmofo
85 s12 ca18et-SOLD
92 fastback-SOLD
91 fastback-SOLD
06 Infiniti M45
ITS ALIIIIIIVE!!!!! ITS ALIIIIIIIVE!!!!! with a cracked timing cover...spewing oil like crazy but it runs!
