Nismo1182 »
https://forums.nicoclub.com/nismo1182-u2371.html
Fri Jul 25, 2003 6:39 pm
1. I used my stock CA TB and my throttle cable bolted up fine.
2. Yea starter has two wires, small ground and the main power.
3. I removed the metal pipe that goes around the back of the motor and most of the hoses i didnt need. Once you remove everything, the stock KA hoses should fit with minor trimming.
4. Yeah thats a good spot. My wastegate line runs the the side of the throttle body. You can also loop it to the compressor on the turbo.
5. The hose coming off the intake tube after the MAF goes to the valve cover vent on the exhaust side.
