Urgent Side Flanges Question
moyea
Car: Paddle Shifted 92 240SX SR20DET, 02 Frontier S/C, 90 240sx ITA
I searched and read a lot of info about the VLSD swap but I think some of the terms are getting confused which is confusing me. So I looked at my FSM for the correct term. On the side of the differental housing are these things that stick out called SIDE FLANGES, not output shafts according to the book, the bolt to the DRIVE SHAFTS(6 or 5 bolts). The VLSD that I bought came with no side flanges. Can I use my open diff side flanges on my vlsd or do I need vlsd side flanges? If no, can I use the open side flange anyways and replace them later on?
I want to make sure the terms and parts are right.
Fenvy
Car: 2005 350Z Base 6MT
let's just stick to output flange since everyone is familar with this term.
from my understanding, you can swap the output flange from your open differential to the vlsd but most people get the 5 bolt start shaped ones because it's beefier
Sockington
moyea wrote:not output shafts
No, because the output shafts are:Half Shafts (aka, CV Shafts,m axle's (not proper term for a IRS vehicle) )
Output shafts and Output flanges ARE different.
God damn nomenclature.
moyea
You guys are confusing me again, lets use the term side flange for differental housing.
moyea
What is the part #?
need2drift
Car: 89 s13 sr20det powered coupe
I'm runnin a 300zx vlsd with the stock open diff flanges on it and it fine.. I have been runnin this for about a year now with no probs...
moyea
Here are some part # 3822051F01 an 00Do I really have to fork out another $200 +/-100 for these shafts or is there another way?
moyea
Is it true that you can buy one side of the VLSD output shafts and use the other side from your open diff output shaft?
moyea
Any help would be most appreciated! I keep getting conflicting info about using the Open diff half-shafts on a S14 VLSD.
