DjLiquid »
https://forums.nicoclub.com/djliquid-u26615.html
Tue May 31, 2005 3:44 pm
Ok, here's the scoop. I decided to clean out the oil restrictor, it snapped off when I tried taking it out. I knocked in the head of a phillips head screw driver in the hopes that I can twist out the remaining threads..........Didnt happen. The phillips head snapped off (about 3/4") in the block. I got a 1/4" titanium bit and started to drill it out but I got just about 1/16" of an inch off the screwdriver bit and i noticed that when I drilled about 1/2" into the block have a half moon thing happening. In the hole I drilled, the bottom half is covered with the screw bit, then theres a space in the middle where I can see a hole, and the top half is the block. It looks like it keeps going. Now here's the question I have.... Is there any part I can take off the engine so I can see the inside of the block where Im drilling? I dont want to go through and hit anything or go too far. I have a feeling that Im off track with this hole and I know I cant make it bigger or Ill have more problems.
I really need this fixed and I only have one day off this week to actually take a look into this problem.... Also, this is the only concern I have with this engine. Once this is fixed, im set. I really dont want to screw this up...
SUGGESTIONS PLEASE!!
