mojo4u »
https://forums.nicoclub.com/mojo4u-u209475.html
Mon Sep 10, 2012 12:22 pm
hey out there.
just wanted to let everyone know that a MAF sensor creates a lot of miss information with other problems regarding power, idle, stalling, etc. Some claim that you cant clean a mass air on a maxima because it wont work. got to replace. False. If you clean with Mass air flow Cleaner. CRC it will work. ELECTRICAL, CARB CLEANER, STARTING FLUID, WILL HARM OR DAMAGE. YOU MUST shoot it in the AIR IN AND OUT PORTS. TINY CHAMBERS ON THE SENSOR. The mass air flow is like the gateway to your car running properly. Most issues regarding fuel, knocking, hesitation, stalling, rough running, irratic idle, check engine light on( P171 CODE) WILL BE THAT OF THE mass air flow sensor. Extremely easy to clean and or replace. YOU DO NOT NEED TO GET UR ECM REPROGRAMMED. Hope this helps all out there looking to drop $ 145+++ on the sensor or more if you have some dealer or shop replace. REMEMBER A CAN OF MASS AIR FLOW CLEANER FOR 6 BUCKS IS A CHEAP WAY TO MORE THAN LIKELY FIXING YOUR ISSUES.
MOJO4U GO JAGS!!!!!!!!!!!!!!
I
