mkory »
https://forums.nicoclub.com/mkory-u17964.html
Fri Aug 05, 2005 10:43 pm
So I finally decided to fix this infamous timing chain rattle. Man, were these guides scraped all to hell. ..Damn you Nissan.
So I DON'T set the motor at TDC thinking nothing will move. Pull off the valve cover, then distributer, and finally upper timing chain cover. Take off the two guides, and put everything back together. After letting the liquid gasket dry, I go to start it. I hear a few bursts, the car is VERY rough, and dies. Somehow the distributer must have moved.
So setting the motor at TDC only means turning it by hand till the little nubbin matches up with the next to furthest mark to the left on the pully. Setting the distributer at TDC means lining up the marks on the end of it.
Here's my question. Has any damage prolly been done due to the ignition timing being off? I took the distributer cap off before doing anything to the motor so I could mark where everything was. The little rotating piece came off at this time. I put it back on like I thought it came off, but I may have put it on wrong. This should line up with the #1 plug wire when the marks on the end of the distributer are lined up, correct? Finally, should I really set the motor at TDC and line up the marks on the distributer? Shouldn't I set the motor at 20* BTDC and line up the marks on the distributer.
