95-J30tt »
https://forums.nicoclub.com/95-j30tt-u40286.html
Thu Nov 15, 2007 6:42 am
same transmission, but the output shaft might be different (where the drive shaft connect to the transmission), i'm sure that the TT transmission has a different output shaft diameter
but i'm NOT SURE if the non turbo 300zx transmission would have a same/different output shaft diameter than the J30 (so check the output shaft diameter before you buy the transmission, because if it is different, then you will need a custom drive shaft, they cost upwards of 250$), if there is two sizes for the output shaft, take the smaller one, that is the one that would fit correctly into the driveshaft.... (both transmissions have the same code, so most likely it wont be different anyway)
other than that everything will bolt in just fine, you will be missing the rev sensor (most 300zx transmissions dont have the rev sensor, but most J30's have them), so you will have one less connection to make (the transmission would work just fine without it, however, every time you start the engine, the A/T light will blink a few times and then goes away)
the wiring is all the same (except for the rev sensor, the rev sensor is NOT the RPM sensor)
keep the transmission mount from the J30, you might need it (it fits better on to the body)
i hope this helps, good luck
