240tek »
https://forums.nicoclub.com/240tek-u12526.html
Mon Jan 26, 2004 9:12 pm
I'm just worried that driving it is going to make something worse. I don't want to tow it, and I don't want to spend a ton of money to fix it. So, I'm trying save myself some trouble by figuring out what the problem is then taking it somewhere to get fixed. If it's simple, I can do it. If it's moderately difficult, Ive got a buddy that can hook me up. If it's a big thing, I'm just screwed. More specifics though: It seems like it works better after it's warmed up. It was also working fine at the end of the night on friday (when I finally pushed it too far, I'm guessing), but when I tried to drive it Saturday, it was messed up. Pedal doesn't seem to have any unusual play or movement. I know that there is a leak somewhere. I've been waiting to get the engine steamed or degreased to try to find it. I thought it was my power steering fluid, but perhaps it's the clutch master cylinder. I'll check that. EDIT: Also, It may help to know that the problem seemed to be getting worse the harder I drove the car. As I revved it higher and then wen't back to normal driving, the clutch ran less smooth, and engaged oddly. It wasn't enough to really worry about at the time, but was probably a sign of a problem. Do you think the clutch just needs adjusting or that it was steadily loosing more and more fluid? Thanks again for your help. PEACE. Tek
