urgent........help
Rishi1331
Car: 06' m45s
My wife has 04 fx45. While driving all the lights came on and the engine stop. I thought I read about this on the fourm for our m45 about a sensors . I'm pissed cause my daughter was also in the car on the hwy.....anything will help
lovemycarM35
Car: 2014 Lexus GS 350
With F-Sport Package
Nebula Gray
19" wheels
12.3 inch display
Navigation
sounds like that camshaft position sensor iusse I know in the 04-06 maxima world we would get the same symptoms is there a code?
Rishi1331
Car: 06' m45s
On my way to the dealer now.....took it in last week for hesitation, now this happened....didn't check for codes...thank you by the way
Rishi1331
Car: 06' m45s
It's the camshaft sensor.......got the sensor for 46 dollars but they're charging me an hour labor.
cruzad3r
Car: 2006 Infiniti M35x fully loaded
you're at what dealer? infiniti or some mom and pop shop?
Rishi1331
Car: 06' m45s
Infiniti .....
cruzad3r
thats good for OEM part. My autozone part was a little bit higher compare to your but much lower compare to my dealer's price. Once you replace it, you're set. Also check my other review thread on torque app and Bluetooth obd ii dongle. It's very useful scanning car for codes as well as monitor it.
Rishi1331
Car: 06' m45s
cruzad3r wrote:thats good for OEM part. My autozone part was a little bit higher compare to your but much lower compare to my dealer's price. Once you replace it, you're set. Also check my other review thread on torque app and Bluetooth obd ii dongle. It's very useful scanning car for codes as well as monitor it.
It wasn't my m45.....its my wife fx45 so maybe that's why.
Back again at the dealership today for the engine service light....
Now they saying the cats are going. 1400 per side...I can't believe it.
Not sure what to do?
The Bodyguard
Car: 08 Infiniiti M35 black loaded custom VIPDOUT
08 Infiniiti G35 S sold 92k miles
08 Infiniiti M45 S sold 78k miles
07 Infiniiti M35 traded 53k miles
95 Infiniiti J30 sold 155k miles
Location: Cypress, TX (Houston) o.g. from southern cali (North Hollywood)!!
Cats?? That sounds crazy!! I would turn that work down... the car wouldn't pass emissions if the cats were going out?! Plus if you do have to replace cats aftermarket will be a ton cheaper so don't do it at the dealer!!
cruzad3r
ask for code, better yet, get the code yourself. unless you see codes, i turn down on all "dealer advise service"
the camshaft sensor will give you a CEL. you can reset this with the torque app and bluetooth dongle i previously review. autozone or advance auto will not clear your code. if you're in a pickle, go pick up a standard OBD II scanner from harborfreight and reset it yourself first.
Rishi1331
Car: 06' m45s
I Def. Said no......I have a mechanic I used for years before I got both infiniti.
Trust them.....so ill be going there and ask them to read the codes...I'll. Do high flow cats if I do anything.
