Urgent help needed: Wheel/Tire fitment question
Davidss
Car: Z06/S2K
Hey I need to know if this will fit without flares, wider fenders, or having to add too much camber. I have an s13 hatch and I'm looking at
rota grids16x810mm offset
front 225 series tirerear 265 series tire
The rear tire size is what I'm worried about. Rolling the fender a bit is no problem. This is for my 24 v8 project car and I really need to order these tires today to get them in time. Urgent help is needed! Thanks!
The car:zerothread/311203
whiterps13
Car: white LE hatch
Dont stagger the tire size. A sticky 225/50 is going to grip just as well as a 265.
They will fit, but just run a 225/50 all the way around so you can rotate..
Davidss
Car: Z06/S2K
whiterps13 wrote:Dont stagger the tire size. A sticky 225/50 is going to grip just as well as a 265.
I already have the tires.
DJButton
Car: 2010 Nissan 240sx
Roll and a pull and you'll be set. A smaller tire would be much easier though, I'd try and get a 245 for the rear and run with that.
whiterps13
Car: white LE hatch
Davidss wrote: I really need to order these tires today to get them in time.
I was going off this statement.
If you already have the tires, then what is the question? They will fit but will require some rolling.
Davidss
Car: Z06/S2K
Sorry that was my fault, I put tires instead of wheels. Thanks for the advice I'll get the wheels in early next week!
nismofly
Car: 89 Nissan 240SX Hatch
the 265 wont fit well at all, hell id say youre pushing it even fitting period, definately wont be in the recommended wheel width range for the tire
265 is the width in mm. Does us no good without the aspect ratio.
We need the 2nd number: 265/__/16.
Either way, those aren't too wide. I ran 275/40's on my S13 with 10" wide wheels with a roll and slight pull.
DJButton
Yeah the problem is, if that's a 265/45 he might be getting close to the suspension too. Well either way a roll and pull depending on how low you go. I mean this is going on the S13 right, so who cares if it takes a little longer to get the wheels set-up right, it's not like the car has an engine yet.
nismofly
im not saying clearance wise, im saying the width of the tire on the wheel
its more than likely a 265/45/16, and every tire i find in that size doesnt have a recommended width range that goes down to 8"
a 265 would be good on like a 9.5" wheel, not an 8
whiterps13
Car: white LE hatch
Exactly what I was thinking.. thats why I suggested going with the 225's all the way around.
DJButton, it wont be close to the rear suspension at all.. Broadfield was running an 18x10 +44 with a 275 and it cleared fine.
DJButton
Yeah I was thinking about that actually +10 anything is way clear of suspension, brain cramp.
JRPS13
Car: 1992 180sx
i was wondering if you guys could help me out with this same situation.i have a 180sx and i wanna run either:
17x8 rota torques all around
or
18x8 fronts and 18x9 rears on rota d2's?
recommendations?
whiterps13
Car: white LE hatch
Start a new thread next time, but with -all- information needed for fitment questions.
What is the offset on the torques?
The D2's only come in 17's and dont come in 8 or 9 inch widths.
