themaddhatter »
https://forums.nicoclub.com/themaddhatter-u12397.html
Sun Jan 04, 2004 4:38 pm
Hiya folks. Here's the problem I'm facing.
My car is a 1990 Nissan 240sx Coupe, 5spd. Manual.
I tried to start the car a couple of days ago and it woudn't turn over. The interior lights were pretty dim too. I jump started the car and let it run for about 10 minutes. I then switched on my lights so I could take it for a spin. As soon as the lights came on, the car started to sputter and die. I saved it by revving, but it died as soon as I let go of the gas. I jumped it again, and this time left it idling for over an hour. it idled fine w/o problems, but when I turned the lights on to leave it died again.
I used a volt meter to test the battery while the car was off and it was around the 9V mark. I tested it running and it showed a little over 14 and was pretty consistent though I didn't leave it in place for more then a couple minutes.
I don't know if this is the alternator or the battery. I also tried pulling the positive lead off the battery while the car was running and it died. It seems to indicate the alternator, but could there be a fuse or relay problem? Seems to idle fine but as soon as the headlights come on it dies immediately. w/o the headlights, I was able to drive it into my garage (10 ft) w/o any problems.
Lastly, I found an alternator fuse in the under hood box close to the battery and it was fine. Is there a charging fuse somewhere else I need to check?
I apologize for the long post, and appreciate any help I can get. This car is my primary transport and I start a new job tomorrow morning. To make the situation more interesting, we're about to have a snow storm tonight. If it wasn't for bad luck, I wouldn't have any luck at all!
