Urgent Assistance
BahamaMack
Car: 2005 nissan fuga
So I have a not so slight whistle under my hood
car runs perfectly
except for this annoying ringin
Initially I thought it was a pulley or a bearing
went to a mechanic and changed bearing
got the altenator check and thats perfect
im lost for ideas wondering if anyone on here can help me or have encountered a problem like this
here is the video
[youtube]http://www.youtube.com/watch?v=nRmTzxrtSc4[/youtube]
Double E
Car: '04 M45 Dark Blue., NAV
Could be the tensioner bearing but I'm curious to hear it with the A/c on and then again off. It sort of sounds like the A/C compressor pulley too.
BahamaMack
Its whistles when the ac is on and off
EdBwoy
Boy, that would really grind my gears! If I may ask, which bearing did your mechanic replace? Those 2 idler pulleys might be the cause. Although I've experienced a bad A/C compressor and it's a raspy sound even when you turn the A/C off. Just to be sure you could remove the A/C belt and see if the noise stops. That's where my money is
BahamaMack
Removed the belt and the noised stopped
so im figuring now its one of my idler pulleys
BahamaMack
Update!!
Changed belts and tensioner pulleys
noise is still there!!! Urgh!!!!
any help?!?!?!!
paranoidjack
Car: 2012 Infiniti M56 S
2003 Infiniti M45
2001 Infiniti QX4
2000 Infiniti Q45
1998 Nissan Pathfinder
1996 Infiniti J30
Well, what belt did you remove to make the noise stop? It is something else on that belt, other than what you just changed...
BahamaMack
Just the belt and my tensioner pulleys
my nex move if looking at the power steering pump and the water pump....
BahamaMack
Once the belt around the altenator is removed the noise stops
