nsrZ32 wrote:Stock mounts should be fine for you. But.....for what its worth, I have the noltec urethane motor mounts and have had them for years with zero problems.
Jerry doesn't drive his car enough for him to worry about it.SilverTwin wrote:
Jeery, Keep a close eye on them. Once you see how they fail it's kind of scarey. I've read of several others having problems with them breaking down and we recently had to replace a set for it. The metal portion of the mount is only heat bonded to the urethane. The set that we had to replace had broken down so badly that the motor had dropped almost an inch and was resting on the steering rack, this happened over a period of about 18 months.
hahaha niceNSR_S13 wrote: Jerry doesn't drive his car enough for him to worry about it.
OK, I'm done. Show me a part number, not a generic picture that is the same as shown for every other motor mount/trans mount on that link. Obviously you are dead set on buying "NISMO" products so please do so, even though the "NISMO" part in question doesn't exist.Zak427 wrote:what are you talking about the second link...
it may say transmission mount only. but click on buy it will show engine and transmission mount kit
http://www.mynismo.com/product...12720
OK, I know I said that I was done with this but it's just getting too humorous at this point. The part number which you so cleverly posted is clearly described as the transmission mount. Now why don't you go ahead and order two of those and see if that generic picture will help you mount your motor with them??Zak427 wrote:oy vay......lol......................here you go
11320-300ZX
