UR VS. JGY pulley ?
2.240s
Car: 240
are these the same besides $$ UR 169. JGY 119. and i should throw in a silk road water pump pulley?
nissanparts.org
Car: 1990 Nissan 240SX
2006 Sentra Spec V
Go with UR all around and your set.
codyace
Car: S14 w/redtop
By running with the UR underdrive crank pulley, you are already underdriving the water pump as well, eliminating the need for the silk road w/p pulley.
HardcorePS13
codyace wrote:By running with the UR underdrive crank pulley, you are already underdriving the water pump as well, eliminating the need for the silk road w/p pulley.
Not necessarily.
Depending on what you are using it for; underdriving the pump up to about 35% is capable of cooling the car. A number of SE-R Cup cars are running large underdrive ratios on their SR20DE's, while those are race cars; keep in mind that the turbocharged engine will produce much more latent heat.
