ur slave cylinder go out as much as mine?
twysteddrifter
Car: 1990 240sx soon to be a carbon s-15
I put in an ACT clutch kit stage 2 and a fidanza full race flywheel and ever since then i have been going through slave cylinders like they are going out of style!!! so far i have put five on and i am wondering if anyone else is having the same problems I have only put one master cylinder since those parts have gone on. the slave is not expensive but its a ***** bleeding! let me know!!! PEACE.
halnfl
Car: cars, woman
are u buying cheap ones or factory?
rawill240sx
Car: 1990 240sx
I've gone through two sets of master and slave cylinders in the past 2 years but they have all been cheap ones from autozone.
240marcuSX
Car: E34 525i
E46 M3
Step #1
stop buying major parts from autozone/pepboys/advance
Step #2
look at your clutch pivot fork, (its the thing that connects to the slave, that moves with the t/o bearing etc.) if you can wiggle it more than you think you should be able to, you probably have a broken clutch pivot bolt, or bent clutch pivot fork, or both.
If you can move it alot, you can probably shine a light in there and see if its broken off.
ddgsxr504
Car: 1995 Nissan 240SX SE 2007 Infinit M35 Sport 2011 Nissan Pathfinder Silver Edition
1. What he said
2. I have an OEM Exedy Clutch, Fidanza flywheel, Stainless clutch line and Autozone slave cylinder and I have no problems what so ever. So I be thinkin that the problem is somewhere else.
If in case nothing is broken then fork up the cash and get the Nismo slave.
