9240sx »
https://forums.nicoclub.com/9240sx-u11838.html
Fri Sep 09, 2005 3:09 am
I love this pulley and if you dont have one on your SR yet,Get one!The UR pulley is maybe 2lbs tops,The stock one felt about 10lbs maybe more,And the UR pulley is alot smaller,looks like a toy.LOL All the timing marks are perfect same as the OEM.
The install was very easy took me a hour from start to finish.Fits like stock with no problems.The only thing is the new belt size for the P/S and A/C is wrong not even a real part#.But the water pump belt listed is right.Other then that no problems at all with the install.
As for gains the car feels alot faster when not in boost or lower RPMS (Below 4g's)As for up top i cant tell,But im sure it made a differents.Water temp stays lower when racing the engine By almost 17degs!Engine revs up alot faster now too.
Got mine from Marty T you sould do the same.
