UpStAtE SoUtH CaRoLiNa
Including AR, LA, MS, AL, FL, GA, SC, and NC
blondjon01
Car: Nissan Maxima
those are S13 SR20DET Motor The S14's Are More Exspensive Like 500.00 To 600.00 Dollars A Stage More ANd What Are THe Numbers On A Stock S14 Motor
JDMEnthused
Car: Nissan 240SX
S13 SR20's are about 205hp and about the same amount of torque, alittle less.. the S14 and S15 are about 15 to 30 hp more powerful than the current versions.. most horsepower is gained from a different turbo.. S15's have T28's and the earlier versions have T25's i believe but the S14 gains horsepower through different cams and head tuning.
Nismochick240
Car: 95 240sx- BONE STOCK.. for now
dont go w/ the s15 unless you get the s14 transmission... the s15 is 6spd but i've heard they cant hold any extra hp-- the s14/13 transmission can hold more power
blondjon01
Car: Nissan Maxima
I'll Proabbly Just Stick With The S13 Seeing As That Is The Cheapest Route And See If I Can't Get Like stage 2 or Three With A Different Turbo
blondjon01
Car: Nissan Maxima
Oh Yea The Price For Those Motors Include Installation So The Might Be kinda High But That Include Motor Trans And Intallation Stage 1 May Include The ECU And Wire Harness I Didn Not Ask But They Don't Have Anything Listed Like THey Do On The Other Stages
scs13
Car: 93 s13 coupe
they have to have the harness and ecu to do the swap. how much are they asking for like a s13 blacktop sr20 swap? what all does that include like the ic and exaust and such?
blondjon01
Car: Nissan Maxima
When They Do The Swap That Price Does Not Include The ECU And Wiring Harness i Do Not Belive You Have To Buy That Separatly I Think...... And A Question What Is The Diff.. Between The Red And Black Top? And I May Be Able To Anwser The Price Thing But The Prices include installation So It Will Not Be The Price Of The Actual Motor And Trans It Will Be With Installation I'll Have To Call Them Back To See If Stage 1 Includes Wire Harness And ECU.....
scs13
Car: 93 s13 coupe
red tops are the older ones and blacktops are the newer engines. the black tops are only like a few hundred more so id make sure i got one of those.
blondjon01
Car: Nissan Maxima
Alright I'm Going To Them Back And See What All Is With Stage One I Think He Said That It Comes With Everythig But I'm Not Sure And To See If THose Motors Are Balck Or Red Tops
97ka-t
Car: 1996 Nissan Maxima
1998 Nissan Altima
Hey guys, I just checked up on this thread..Firstly, there is a differnece between S13 red top, S13 black top, and S14, and S15 SR20DET's- most obviously age. S13 redtops are the oldest and barely put out 180 at the wheels. S13 black tops put out maybe 10 or so more HP. S14 SR20DET's do not use the T25 turbo that the S15 uses, and it will create around 220hp. But, the S14 and S15 engines utilise VVT (Variable valve timing- it is engaged from about 1k RPM's to around 5k RPM's to give S14 and S15 SR20's a slight boost in low to midrange torque) The significance of a S15 SR is the fact that it uses a ball bearing T25 turbo, they were made in 6spds and automatics. The 6spd transmission is not as reliable and really not much of a benefit. Instead of just swapping trannies and paying an assload for the engine, buy an S14 SR, and simply swap out turbos, it is a bolt on job, and can be done by just about anyone. Also, as far as this shop in Raleigh is concerned, I think I've been there before.. Got a NSX, among other things sitting out in front of there.. Nice facility.. If they don't install EVERYTHING for you, I'd order a front clip, maybe through them, maybe through another person- get the clip, and just pay to have that installed. For example, the shop I get most of my stuff from (ViS hood, Buddy Club JDM wheels, etc) is Urban Import. It's off Hillsborough Rd in Durham. I think they quoted me somewhere around 1-1.5k to install an S14 SR, everything running. If I were you, I'd save the extra cash, buy a Zenki, and KA-T the bastard! I know a little more about KAT than SR's/RB's/CA's.. Just drop me a line if you need help
blondjon01
Car: Nissan Maxima
Well See The Reason I Was Looking At This Place In Raleigh Is Becuase They Told Me They Could Get Me The Car For Somewhere Between 150.00 To 600.00 And That Would Save Me Alot Of Money As Far As The Car Is Concernerd...... Cause Right Now I Have A Nissan Maixima And i Was GOing To Do A SR Swap On It But They Told Me That Would Be Kinda Stupid Seeing As I have A V6 3.0 In There Now And My Car Is Heavy Unlike The 240 And THe Sr Wold Do Alot Better In The 240 Which Depending On THe Horse Power It Should Not Matter How Heavy THe Car Is.....1 The Motor Is Alot Lighter Than The V6 The Motor I Would Be Putting In There I Would Say Don't No How Much Power This Stock V6 Is Pushing But 400 HP Is Alot More Than It Is Pushing But Oh Well Still Chacking Options And Places TO Call To Check Out Prices And Stuff.....They Also Told Me To Think About Takin And Putting The Skyline Motor In The 240 Or The Maxima But I Think It Was In The 240 I Don't Know They Got Me Confused.....If You Guys Could Give Me Some Good Places To Call Kinda Local Here Or Around SC That Would Be Good..... Kinda New At This Whole Import Thing If Ya Know What I Mean
scs13
Car: 93 s13 coupe
theres a place here in greenville that does sr/rb swaps. its called rims and things, i went there to check it out and the people seemed like idiots. they told me they didnt have any sr's. but there was an s14 front clip sitting right there. they also had an r33 front clip with an rb25det that i checked out. i dont know about the quality of work they do, it seemed kinda sketchy and i havent heard anything about them. but the site is http://www.rimsandthings.com if you wanna check them out. i wouldnt really recomend them unless you hear something good from somebody about them.
Nismochick240
there is also a guy in spartanburg that specailizes (spellin lol) in sr swaps and ANYTHING to do w/ a 240 (he got a green 95 thats got around 325 on just a boost controller N exhaust lol) but here's his cell ##864-266-3930... he does a good job-- when i was thinkin of goin sr i was gonna go through him... p.s go buy an iwanna there are 240s in there for like 300-1000... there's a 95 in there that needs a timin chain for like 900 bucks... dunno if its still in there though... check it out!!
scs13
Car: 93 s13 coupe
theres also been a few sr and rb swapped 240s on the iwanna and for sale around here recently too. its getting hardcore popular which makes me want to go ka-t even more. most of those cars are pretty cheap too, id just make sure everything was done right if i bought one from someone.
Nismochick240 - i think i saw that car at the haywood mall a few years back, it was pretty nice. do you know if he ever comes around the greenville area often?
97ka-t
1998 Nissan Altima
Hey! If you can get me in touch with that $900 zenki, that'd be awesome I'll take it!
Nismochick240
hey guys! i dunno its dark green n it has a dent in the driver panel so dunno if that was it... there is also another green one w/ an sr in it that rolls around here that has big rims on it like 8x10's or s/t... dunno
97ka-t-- i'll have to look it up when i get home and see if i can get it okay?? i'll let ya know check back around 10am ok?!
blondjon01
Car: Nissan Maxima
Quick Question Alicia How Do I Put The Nico Banner On Myspace Like The On You Have Up
Nismochick240
(...alisha) uh i have photo posting i coped a nico banner from here to my computer and then went to http://www.mypicgallery.com and uploaded and you can get html to put on ur myspace
JDMEnthused
Car: Nissan 240SX
S15's use a T28 turbo with a ceramic wheel..
blondjon01
Car: Nissan Maxima
Srry I Didn't Spell Your Name Right I'll Make It Up To Ya Next Time I See Ya (I'll By You A Drink Or Something)
sc_specv
Car: 04 sentra se-r specv
chris/22/orangeburg/04specv
scs13
Car: 93 s13 coupe
woo, we got like 6 people now. that s14 i was talkin about was like light green and it said silvia in the front grille and had an sr i guess. thats all i can remember because it was like 3 years ago or something. it was bad though.
97ka-t
1998 Nissan Altima
You're right.. I'm not quite sure why you mentioned that.. Just because it spools faster because of low inertia? S15 turbo's were dual ball bearing T28's. If you want to check up on it, the part # is 14411-91F00. Older SR turbos were T25's I believe... S15 T28 is something like 10-15% more efficient than the S14 T28
JDMEnthused
Car: Nissan 240SX
yeahh.. i was late on getting back on the reply heh. the skyline T28's had a metal wheel that could hold more power with a smaller exhaust housing.. about the same A/R though
and.. your also right about the older SR's being T25. good job.
97ka-t
1998 Nissan Altima
Phew. Was afraid I might be wrong! haha SR's are nice and all, but it's like putting a turbo Miata engine in your car (1.8L as compared to 2L) and we've got just a little more weight . Well, anyways, I'm off to take the jig saw to 3/4" MDF board and go buy a bunch of fiberglass/resin to build my wheel well sub enclosures for my JL 8W7s. This is going to be quite time consuming.. and pretty damn pricey.. $2.50 a sq. yd for fiberglass online, but the local store wants freaking $7.... $25 a gallon for resin... need to buy fleece.. etc etc.. Oh well, It'll look b-e-a-utiful when I'm done
blondjon01
Car: Nissan Maxima
Yea I Need To Do THat My Maxima Came Factory With A Bose System In But When I Bought It They Ripped Everything Out Ever THe Freakin Factory Speekers But Never Mind THat I HAd A Hell Of A Stereo System In My Explorer...13 Speekers (Mid's And High's) And 2 12'' Rockford Fosgate P2 And A 1200 Watt Amp Pushing Them I'v Got 9 Speakers In My Maxima RIght Now But There Sitting All Over THe Place Becuase The Speaker Holes Are Way TO Small Not To Mention All The Bose Speakers Have Individual Amps On Each Speaker And I'm Going To Try To intergrate The Amp Into My System All I Have To Do Is One Get A New Radio Cause I Have Had THe CDMX 600 Sony Fold Down Since It Came Out In 2000 It's Old And Not Working Right Then I Have To Make Sure The Radio I get Has Enough Line Out Plugs On It ( RED & White) Cause You Can't Run Preamped Stuff To The Factory Amps Just Won't Work.. And They Glued The Freakin Screens Down In THe Rear So I'm Going TO Have To Replace That But Now All THe Speaker Are Sitting In THer Floor Boards....... Sounds Pretty Good But I 'm Not GOing To Do All THe Fiberglassing And Crap On THis One Becuase One Trying TO Save Money To Pay This THing And Get The 240 And Motor And Everything Else But Still WOuld Like TO Have Speakers Out Of Floors.......LOL But If NE One Know Where I Can Find A Good Stereo For Not THat Exspensive Let Me Know
97ka-t
1998 Nissan Altima
Firstly, I'm wondering why the hell you're capitalizing every single word... haha don't do that, it's annoying. Also, you should buy speakers that fit in your stock holders, you should have at least four there. (six including custom mounted tweeters). You don't really need more than that. Also, I'd be willing to bet that my two 8" subs would destroy your 12"s I'm going to be selling four of my Phoenix Gold 6 1/2" speakers and 500/4 Phoenix Gold amp in a little bit if youre interested. I also have a MP3/WMA Kenwood head unit...
97ka-t
1998 Nissan Altima
Oh yeah, also, just bypass your stock amps, that's what I did.
JDMEnthused
Car: Nissan 240SX
yeahh that does sound pretty time consuming.. i would really do it, im trying to get rid of my subs and just leave the front speakers.
blondjon01
Car: Nissan Maxima
I Already Took All THe Amps Out I Went Out There Today And Put My Speakers In I Cut Bigger Holes In The Existing Mounting Brackets And I Have 4 Boston Acustic 6 x 9's And 4 Boston Acutic 4 x 6 1/2 I THink Thats What They Are And 2 Boston Acustic Tweeter That Are loud As Hell.....I Like TO Play My Music Extreamly Loud........ Don't Know Dude Those 12's Are Pretty Strong There Loud As Hell In This Car But I Hate All That Ratlin **** Never DId It In The Explorer Cause There Was No Trunk just Alot Of Open Space but THis Car Rattles Like A Mother But I'm Not Going To Say Your 8's Arn't Going To Beat Them Not To Mention Don't Know What Kind They Are But I Know They Would Not Beat The One's I Blew At A Competion In FL Last Year
Return to “Southeast Region”
