Dmsrstar »
https://forums.nicoclub.com/dmsrstar-u126364.html
Tue Feb 24, 2009 3:56 pm
Hey guys just been lurking but need your help.Please anyone in or around upstate NY, Ithaca area, or someone who can drive up to fix my s14 with a s14 sr20det, ill pay for your gas and ill pay you 100 dollars cash to just look at it and tell me why its running the way it is. If you can fix it, EVEN IF ITS SOMETHING SMALL ill pay you!! This isnt a joke. Please If you can let me know now!!! I need someone tomorrow and I need to know, bc if not ill just tow it to a shop local, but I dont trust them. By the way its a fresh swap so, hasnt driven perfect ever, and cant get it to.
Just to tell you what its doing..
Idle bogs down when I let off the gas, and at idle it does it only rarely but still idle is bouncy
I try driving it and its almost so bad I cant, no power untill past 2500rpms it feel like, and cant go wot, it just kinda dies at wot. Wont go into boost.
Rough and feels like a misfire every few seconds, at idle and driving it
Seems to run rich bc the before changing plugs and 02 sensor they had dry black power on them, that smell like gas.
Its almost undrivable, its that bad.
Just cant figure it out for the love of me, ive tried new plugs, and gapped them at 28. Bought a new 02 sensor. I think I check the hoses good enough and found no boost leaks. Turbo is good, and lines good. Took battery out for two nights to reset ecu. MAF sensor seems to be ok.
Mods are new 2871r turbo, oil lines, with all the gaskets replaced around the turbo area, 02 sensor, 3 inch exhaust, older super afc, which my buddy hooked up to the ecu and i really dont know how to work it, dont think that would f*** it up.
Another thing is the car was put together with the help of my friend in the south, and when it was down there in atlanta GA, it seemed to run MUCH better. As i drove it up it got worse it seems, when I got home I let it sit for a day or two and started it up and BAM, it has these problem. SO not sure if its the weather or not.
Please someone help!!! Ill pay you cash this is no joke!!! Even if you give me help over the phone and it fixes it, ill send you money though pay pal. DEAD SERIOUS. Thank you for reading.
