yes stage 1nismofly wrote:you got the stage 1 i take it? so how much power is to be expected?lol
looks good, tell us how it goes
thanks for the kind words. The spark plugs wires should fit nicely between the runners without issue (I can already tell I'm going to have to wrap the manifold though unless I want to burn through them) I don't forsee an issue removing the plugs. i may have to get a jointed extention for my socket but I doubt it. Thanks for the observation though I'll post a definite response to that issue after it's installed. I removed all my AC components . I just like tubular, equal-length, top mount manifolds the best. Reason 1: turbo selection. I eventually want to be in the upper 400 to mid 500 hp range when I'm done. a top-mount manifold will give me the ability to use alot larger of turbos than a bottom mount. Reason 2: lack of selection. I only know of this manifold and top/bottom mount log-style manifolds for the SOHC. I REALLY wanted a tubular-equal length manifold for the difference in performance (I dont like having to spend money twice) I think there was a thread about the performance advantages earlier so I won't get in to that here.wild_maxx wrote:i am curious why you got the top mount for the SOHC? will you be able to take out your spark plugs with the turbo and mani on? did you go with top mount to keep your a/c? you should make your hp goals with that turbo, i am running a strainght t3 .42 a/r @ 10psi and it is jsut amazing. no dyno numbers yet but its soo much better than NA. good luck with the project and keep us updates. always cool seeing another SOHC ka-t.
thank's for the head's up fiz. I'll be sure to watch it. The manifold is warrantied if that happens I should be coveredfiznat wrote:I dont want to be a killjoy but just be careful with that manifold. I personally know of three people who got their manifolds from IAP and had that wastegate extension thing crack or break completely off. Be sure to keep your eye on it!
thanks for the advice, wild_maxx brought this up too. I've been looking for an excuse to get some more Craftsman toys anyhowtoki wrote:mmm top mount with SOHC. I remember the first time I needed to change my plugs hahahahah. Let me save you some time, go to sears and buy the spark plug tool that has the swivel/pivot on it if you don't want to take your turbo off every time you change plugs
A nico member locally here in orlando.... interesting..!!R240sx wrote:Now that looks very nice !!
