It has x2 10mm bolts close to the valve covers and also has x1 10mm bolt closest to the where the passenger side mount goes (take your time and look for it).AWDB12wagon wrote:Okay, so Im trying to take my motor I just got appart....I got the CAS off, the motor mount, motor mount bracket, the alternator, the water pump pully, and all the bolts in the front and back of the timing cover off....I cant get the flipping thing off, it seems like its stuck on something...anyone got any tips?? Thanks!!!!!
They sold you bottom of the barrel garbage. That's unexcusable and if I were you I would definitely let them know how upset I am. Something funky about the name "Rims and things">>>>>>>>>>>>> . Anyways, give them a chance to make good on this mishap and let's see how it goes.AWDB12wagon wrote:Can you use valves made for the CA18DE? Are the exhaust valves sodium filled? I didnt want to have to do any major work on this thing, I just wanted to put a timing belt in, some rod bearings, and go....
Bro, let me say something to you,unless you have some agreement pre-arranged with the folks that sold you that engine, I wouldn't go tearing stuff apart and then still expect a refund of some sort.AWDB12wagon wrote:How about that broken timing belt and the exhaust manifold washer between the cam lobe and the head?
