MarkEmark »
https://forums.nicoclub.com/markemark-u744.html
Tue Nov 25, 2003 9:18 am
Okay, so I've been searching around about the infamous "rattling/knocking" sound of the KA timing chains...and have found out a lot of contradictory information.
I've had my valve cover off numerous time and have had my camshafts removed twice since I've had my car. On my upper timing chain, I noticed two of the links were somewhat damaged--They did not seem to be "terminallY" damaged, that is, they seemed to be structurally strong enough to be fine (otherwise I would have replaced the chain.). However, it seems that ever since I replaced my camshafts with higher lift/duration cams, the engine has been making that weird rattling/knocking sound that I hear of so frequently...The sound is not that loud, but is pretty easy to hear at idle, and the sound NEVER goes away, warm or cold, idling or not (although I can't hear it when I'm moving bc of the turbo sound/exhaust).
However, it did NOT make this sound prior to my getting aftermarket camshafts. (the sound could have cooincidentally ocurred right after instaling the camshafts, as well, because prior to this I wasn't really listening for sounds coming from the camshafts). And it has nothing to do with valve lash; I've had 2 sets of custom shims through my head to make sure the valve lash is in spec. The sound seems to be coming from everywhere on the head, not just toward the front of the engine, although the sound seems to be more prominent toward the front of the engine. Would the higher lift/duration cams, along with the perfectly in-spec valve lash cause this sound? Or is this sound being caused from my timing chain because it's not in too good of shape? (I have ~95k miles, btw, and my car's NEVER been abused..and i hear that they're good for another 55k miles...).
My question is: I hear a lot of people discussing removing the top/side chain guide. What are the adverse effects of this? Can you access the side chain guide WITHOUT removing the cam sprocket cover (it's a pretty involved removal.) Does it sound like removing them would cause the annoying sound?
Number two: Would the fact that the timing chain has some "chips" it would appear on 2 of the links cause this sound?
Numer three: Could this sound be caused JUST from the fact that I have high performance camshafts in my engine?
Number four: How concerned should I be with these "chips" to the links of the upper timing chain? I would NOT want that chain failing under high load!! (i'm boosted as well, btw, 9 psi)
And number five: If I DO end up replacing the upper timing chain (which I may very well do), after you remove the cam sprocket cover/cam sprockets, does the upper timing chain just slip off of the idler sprocket? Reading my FSM they make the timing chain seem like an INCREDIBLY involved process, which i assume is because they're discussing doing a COMPLETE timing chain overhall (they say to remove the intake/exhaust manifolds, cylinder head, oil pan, etc...). If it's just a matter of removing the camshaft sprockets/the timing chain cover (cam sprocket cover), then it wouldn't be too bad of an install.
Anyway, I'd love some factual, 100% true information from some of the guys who have done it or know exactly what they're talking about.
Thanks a lot in advance....Marc
PS--Can anyone host a video (small mpg) that would convey the sound I'm trying to explain?
