deviousKA »
https://forums.nicoclub.com/deviouska-u9381.html
Mon Feb 20, 2006 1:25 pm
Pop all of the camshaft bearing caps off and look for signs of seizing. If it wasnt that, it was due to incorrect cam timing and a valve hitting a piston, locking up your cam.
There could also be a slight possibility that the cam had a latent crack to begin with, doubtful as the chain is broken, you cam seized.
Edit: was the cam gear and the portion of the broken cam still sitting half way in the journal, or was it laying down in the front cover? If it was laying down the front cover, the chain breaking was the last thing that happened.
Start pulling the head.
