Upper struts or anti sway for better results
munsterrr
Car: 95 240sx SE, 2005 FX35
im starting with simple suspension mods first and was looking for peoples opinions on what to get first. which ever one i get i will prob get front and rear at the same time.
if you have any other opinions on first mods let me know. i will take it into consideration
meglinton
Car: 2011 G37 Sedan
Anti-sway first. Some people believe that upper strut bars are nothing more than ornamental. I think they still do a good job of keeping everything stiff, but the sway bars are the way to go first.
Get coils first, though. Or at the very least a well matched spring and strut combo. Handling upgrade, as well as a tightened stance.
munsterrr
ive been thinking of going with struts and springs too but i am a little tight on money and just wanted to start with all the small things first. then in a few months go have fun and get nice things
krazydriver
Car: 2002 civic ex, 1993 KA-T 240sx - parting it out...
You don't need coils until you get a feel for the car. And even then unless your properly using their adjustability (corner balancing, full race alignment etc) it's not worth it for the cost.
In my hatch, a rear strut bar MAJORLY tightened up the back end. If you have a coupe, it won't do hardly anything.Check out the fabricator sub forums. I HIGHLY recommend Jonnie Fraz's bolt in tension arm brace (It's pretty much a bolt-in nismo power brace).It greatly improved my turn-in because of decreased flex in the front end.
Soravia
Car: 2003 Audi A4 1.8T
Stock anti-sway bars are really thin, rubber bushings are spongy and the bolts that hold the sway bar can be bent easily.
Upgrade them along with bushings for your control arms.
