brmiller »
https://forums.nicoclub.com/brmiller-u129.html
Wed Aug 14, 2002 1:06 pm
The Nissan Factory Service Manual (for my 1995 240SX) says that the 3 nuts on the "strut mounting insulator"--sometimes called the 'upper strut mount' or 'strut bearing plate'--should be torqued to 29-40 ft-lbs. (or 39-54 N-m, or 4.0-5.5 kg-m).
Unless someone can say why less/more is better, I would torque the nuts to the same measurement. BTW, the nuts should be tighted under unladen condition with the tires on the ground.
Hope this helps. S13s and later model S14s may be different, but this is at least something.
Brendan
