upper radiator hose connector leaking HELP!!
achaney2k01
Car: 1997 Infiniti J30
I was hoping you could help me w/ a problem! My 97 J is losing water from a short hose that connects to the block (i think it connects to the block). The top hose comes off the radiator and connects to some aluminum and back to a sshort hose just before the block. I was wondering if you knew what that hose is called? It is centered over the top of the fan belt shiv. ANy direction or help you can give regarding access and proper identification (part name/number) would be greatly appreciated!
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
THis is called the upper radiator hose..... Theyre not expensive from Joe and theyre easy to install..
achaney2k01
really? the short one between the aluminum piece and the block? i know the long one off the top of the radiator is called the upper, but the little piece in back next to the block that is mega hard to reach i thought was different... sorry, not to be persistent, but just want to clarify. also if you know what i have to remove to get to it, that would be super helpful too..
thanks!
achaney2k01
here, pictures of the problem. Or, pics of the general area of concern!.. and who's Joe?
achaney2k01
here's the view including the upper radiator hose...
elwesso
2007 BMW M Coupe
Are you sure its not the water pump thats leaking? That just looks like a straight piece of hose, id just take it off and get some of the right ID from autozone or something.
achaney2k01
Wes,
Fixed it. Turns out it was that clip that should be sealing it. It was brittle and weak so I threw a hose clamp on it and it's tighter than d!ck hatband now.
Thanks for your help!
