Qgrappler »
https://forums.nicoclub.com/qgrappler-u270.html
Tue May 13, 2003 8:50 am
Greetings to all
No questions this time, just an update, as Im taking a rest after having done the upper link and shock on one side. Upper link was no problem after breaking the bolts loose, and the upper anchor bolt which has tight access to the front side is easy if you have first removed the shock.
Compressing the springs was a PITA, using a v-shaped compressor I got from Harbor Freight for about $30. DIdnt put the jaws on far enough apart to begin with and had to do it twice, but eventually got it.
Little out of perfect line on the bottom bolt for the shock, but not so much that I couldnt slip it on and tighten it up.
For those who change shocks without the service manual, DO NOT LOOSEN THE NUT THAT ANCHORS THE UPPER ROD OF THE SHOCK UNTIL YOU HAVE REMOVED THE WHOLE ASSEMBLY AND HAVE THE SPRING SECURED IN A COMPRESSOR. The assembly comes out easily by removing the two nuts on either side of the center nut up under the hood, and then removing the large lower nut that holds the shock to the wheel assembly. The spring stays compressed against the lower lip of the shock and the upper mounting assembly which is held in place by that critical center screw.(no i didnt do this, at least, but I remember reading a post of someone who did.
I have the tension rods to do also, but Im going to postpone them until I feel like pulling the bottom cover, since it appears I need to do that to gain access to the inside bolthead.
